跳转到主内容
加入维修社区 - 创建账户
MacBook power button doesn't work after disassembly
I followed the instructions from this site that refers to desassemblying the laptop in order to change the speakers (MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement andMacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement). Everything seemed to be perfect but now the power button doesn't work. The button that indicates battery level works. Any ideas?
MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker图片
指南
难度:
中等
30 minutes - 1 hour
MacBook Pro 13" Unibody Mid 2009 Left Speaker图片
指南
难度:
困难
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Is the keyboard connector properly connected and seated? If so, check to see that the cable that connects the keyboard to the power button wasn't damaged when you replaced the subwoofer and right speaker.
完成的
The problem was at the keyboard's connection. It hadn't seated properly. Very thankfull. Many thanks.
完成的
添加一条评论
1个答案
最有帮助的答案
Try this: Turn on Macbook Pro with Power Pads
See if the system boots up. If it does is the trackpad & keyboard working? Test all of the keys!
If not your ribbon cable is not seated or the logic board connector is not latched
这个答案有帮助吗?
得分 3
2条评论:
I use a piece of tape on the ribbon cable and use it to fully pull the cable all the way in the slot before clamping it down.
完成的
@mayer - Good point!
完成的
添加一条评论
添加你的答案
lefterios 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 183
