跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1697 个问题 查看全部
My ps4 wont eject my disc
For sometime now my ps4 is for some reason not ejecting my disc when I press the button it makes all the correct sounds and you can hear the disc being pushed out but it never pushes out completely so I have to stick a qtip n push out the disc I have the latest version of the ps4 so I do not have the manual eject screw but what I did notice is when I push my qtip further down the disc bay it pushes down some sort of lil button which immediately spits the disc out please if someone could help me without having to open my ps4
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
4条评论
What is the model of PS4 you are working on?
完成的
Its the CH 12 series
完成的
Plus using a screw thing is the same like how I use the qtip I dont want a temporary fix I'm looking for like a permanent fix
完成的
Plus I think it may be caused by the dust being accumulated in it
完成的
添加一条评论
6个答案
已选择的解决方案
For the 12xx series they do have a manual eject screw (I'll link the video below)...in fact every model of PS4 does. BUT in your case I don't think you need to manually eject it. It does sound like the rollers inside the disc drive are probably really dirty. It's also possible they are scratched up too.
Unfortunately, there is no good way to clean them without disassembling the console. I know you were hoping to be able to fix it without taking anything apart, but I don't think it's possible in this case.
I hope this helps.
Here's the manual eject video for that model
这个答案有帮助吗?
得分 1
1条评论:
Is there a permanent fix for this?
完成的
添加一条评论
Here is a link with step by step instructions. The only thing you should have to take apart is popping off the top cover. https://ps4.wonderhowto.com/how-to/manua...
这个答案有帮助吗?
得分 0
1条评论:
I have the latest version ps4 it doesn't has the shiny plastic and doesn't has the screw
完成的
添加一条评论
Found the most accurate solution for this problem at https://ps4dns.com/ps4-keeps-ejecting-di...
这个答案有帮助吗?
得分 0
添加一条评论
https://fixps4error.com/ps4-port-forward...
PS4 Port Forwarding – Have Look To Table Of Content
Table of Contents
  • PS4 Port Forwarding – Have Look To Table Of Content
  • Using A DNS Server
    • Static DNS IP for PS4
    • Manually configure a static IP address on the PlayStation 4
  • how to change nat type ps4
    • How to set up a static IP address in PS 4
    • Configure A Static IP Address In PS4
    • How To Set The IP Address Of PS4?
      • What is the IP addresses?
      • PS4 and Xbox Port Details
      • What are the port numbers for ps4?
    • What is port forwarding?
      •  Do ports use PSN?
PS4 Port Forwarding, many Internet providers, the network is set up in such a way that it does not take into account the needs of online games.
In practice, this means that the ports that are needed for the game are simply blocked. The problem is typical for both consoles and computers.
Ports are connection gateways; they are used by services to establish good communication between the PC and the game server. Almost all services often encounter the fact that the ports necessary for operation are blocked.
This manifests itself in the form of inability to connect to friends, difficulties in connecting with the lobby, frequent network breaks, high ping, etc
it is possible to manually configure port forwarding. To do this, you need to use a Wi-Fi router or a modem with a router function. To switch ports for Apex Legends,
Open a web browser (you can use any) and go to the settings page of the router. IP addresses 192.168.0.1 and 192.168.1.1 are often used. To accurately determine the desired address, you must flip the router and read the address on the bottom panel of the device.
Immediately after entering the address into the browser, you need to enter a login with a password, which is the default admin.
Go to the “Port Forwarding” page if the English interface is Port F The required section is often located in the LAN connection settings. Set forwarding of the necessary ports. Each platform uses different ports.
这个答案有帮助吗?
得分 0
添加一条评论
'''PS4 External Hard Drive - Top Product Of 2019'''
Additional (PS4 External Hard Drive) Memory, External Hard Disk Drive or HDD Case Purchase
As to additional memory  PS4 , you want to use on  external hard drive with a USB 3.0 connection,  Which you want to connect to the console in one of the free USB ports. There are so many models of discs that are right for you.  1 TB,  like the one available on the Amazon link indicated below.
Alternatively, you can reuse old  2.5-inch Hard Drives  Inside  HDD case,  so as to turn it into an external USB drive. The  best HDD  case model you can buy on Amazon is the following.
List Of Best External Hard Drives For Playstation
Seagate 7200 BarraCuda
A single-plate storage unit weighs only 400 grams and is very compact at the same time - its  dimensions are 10.16 × 14.6 × 2  centimeters. I am pleased with the rather high shock resistance of the component which is 80 G. The noise level of the unit is low and varies between  23-24 dB . The average delay time of the  HDD  is 4.16 ms, which is not much.
  • low  power consumption (5.3 W)  in the load;
  • Maximum  noise level of 24 dB .
Spindle rotation 7200 rpm Cache 64 MB Volume 1024 GB power usage 5.3 W WD
这个答案有帮助吗?
得分 0
添加一条评论
Here is a link with step by step instructions. The only thing you should have to take apart is popping off the top cover. https://ps6dns.com/ps4-ce-30005-8/
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
akbarmubashir 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 31
过去 30 天: 121
总计 115,039
