Can you fix lose hinges?
my hinges are lose. and i'm not sure if i can fix it myself or where i should send it to get fixed
@snookiex628,beth, You are not the only one with this loose hinge issue, if still under warranty consider using the warranty for repair/replacement/refund. If not under warranty check the links below for a pretty much low/no cost fix and other info. Other wise you may end up having to replace the upper and lower case. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=lj0C4yyI...
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 79
总计 17,659
1条评论
You could try getting a replacement hinge and installing it, but that's pretty hard if you have never done a repair on a 3ds yet. If it's still playable just deal with it (my dual ips 3ds wobbles like crazy!) or if you can't stand it send it to nintendo
由 Leonhard Bokowski 完成的
