跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1696 个问题 查看全部
need a schematic of ps4 motherboard cuh 1004a
hi every1 im new here and i need help from you
ihave ps4 with hdmi problem because i broke some component in motherboard
(hdmi capacitors + diods ) so for that i need a schematic
specially the hdmi schematic
and thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
3个答案
已选择的解决方案
As far as I know, there are no schematic/boardview/service manuals available for the PS4 yet. Your best bet would be to buy a broken PS4 and take the required capacitors and diodes from the dead board. I am sure 3rd party PS4 repair centres will have some dead boards lying about...
这个答案有帮助吗?
得分 4
5条评论:
any other sollution than that?
完成的
Unless you are able to get a schematic and board view for this, no other solution, unless someone knows the value of the components required.
完成的
Couldn't he just buy the right size ones on ebay
完成的
mr gamer 3002 pro ps4 nobody knows what the right values are . It's not the size that matters it's the electronic properties of the component that matters. So no you can't just go and buy something,
完成的
if you have same mother bord can replce same part then its wok
完成的
添加一条评论
I've been looking hard. Found this, among others, for the diode values. I'm still looking for the resisters. Will post when I find.
这个答案有帮助吗?
得分 1
1条评论:
The 3 circled are a DZ2705600L.
https://www.ebay.com/itm/254629809041
完成的
添加一条评论
Can't say for sure because I haven't tried yet (I'm having the same problem) but I think this is at least one of them
http://www.mouser.com/ProductDetail/Taiw...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Simioli Moh 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 73
总计 19,879
