跳转到主内容
加入维修社区 - 创建账户
2005 年 12 月推出的惠普台式机,使用 Socket 939 AMD 处理器。
Computer won't boot up
Push power on button machine starts up power wise and get real quite nothing appears on screen
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
is the monitor hooked up?
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi! from a hardware perspective, so many things can cause a monitor to not show an image.
-Start with making sure the Monitors are plugged into both the PC, as well as the Power Bar.
-Try a seperate Display cord. (Your VGA, DVI, HDMI, or DP Cables could be failing)
-Try a different port. (most recent motherboards support both HDMI, as well as DVI,) or if you have a video card installed, be sure to try your on board port.
-Try a new monitor if it does not work
-if this does not function, try putting your windows Disc into the Drive, and see if the PC Will boot to this
-If this does not fix it, then look into disassembling the device, vacuuming out the device and components with an Antistatic bristle head, adding new thermal paste, and reassemble the device.
-If this does not work, try a new Video card. if this doesnt work, likely your motherboard if failing.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
dtsmith8 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 23
总计 1,433
