跳转到主内容
加入维修社区 - 创建账户
Whirlpool(惠而浦)品牌顶开式和前开式洗衣机的维修指南与支持。
How to fix error code F08 or FOB
Washing machine starts up and after 2 seconds it stops and this code came up. Have to reset the washer cause the door locks. Ive tried various different loads and even a empty load but no luck.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
fscr10420 error f08
由完成的 分享
I have had a brand new machine installed Friday the 10th,the very first wash came up F08,have phoned manufacturers and Indesit,,they have booked a appointment for 5 days,this should haven't happened as brand new.
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
jmears83 , You did not state your model #. This is info i had come up with, F08 indicates that the heater is an open circuit. Check the heater wires for dislodged or burnt wires and check the heater for continuity with a meter.
Check the link below for further info. and view the video. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.espares.co.uk/advice/0/3521/w...
这个答案有帮助吗?
得分 2
1条评论:
hi
me i have replace the heater and the ntc at the same time the cable system is ok but the problem still going...what else i have to do???
由完成的 分享
添加一条评论
I have the same problem. Replaced the heater, washer functions normally except for the error at the end of the washing when it shows F08. My brother also had the same issue but his machine was repaired at the shop. Mechanic couldn't figure it out (why it is still showing error) so he reprogrammed control unit just for that…
这个答案有帮助吗?
得分 1
1条评论:
ok very usefull info but unfortunally here in company nobody knows how to reprogramming ,,,all says to replace the control unit and my friend this costs money ..(for nothing????).
由完成的 分享
添加一条评论
添加你的答案
jmears83 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 82
总计 68,531
