跳转到主内容
加入维修社区 - 创建账户
The Samsung Galaxy Tab 4 10.1 is the fourth generation of Samsung tablets that has a larger screen, higher camera resolution, and 1.5 GB of RAM.
My tab 4 screen doesn't work
Hey, my tablet screen went black but the tablet works you can hear charging sounds.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The Samsung Galaxy tab have a issue with there batteries . This may be the problem ,you can resolve the issue by disconnecting the battery and then reconnecting after a minute or so of being unplugged. While you have the tablet open it would not hurt to inspect the display cables to make sure there plugged in properly . This guide will help with the opening and unplugging of the battery , you dont need to remove the battery just unplug it
Samsung Galaxy Tab 4 10.1 Battery Replacement
Hope this helps
这个答案有帮助吗?
得分 2
添加一条评论
Was it dropped? If it was dropped, the cable that plugs the display into the board could have come out causing the screen to go dark.
If not dropped, it might be possible that the display unit needs to be replaced.
Cheers
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Taric Butter 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 258
