跳转到主内容
Panasonic ARC ES-LT3N was released in April 2015. The sure-grip handle provides ergonomic comfort, and advanced 3D Multi-Flex Pivoting Head that moves up-and-down, side-to-side and back-and-forth to conform closely to facial contours for more efficient shavings.
3 个问题 查看全部
Why is my shaver not working as efficiently as it did previously?
Overtime my razor has continuously worked less efficiently, I am looking for reasons why?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Student, iFixit Technical Writing Project
完成的
添加一条评论
2个答案
最有帮助的答案
@atrainor1 , Andrew, Some reasons why electric shavers loose efficiency. On electric shavers the blades can become dull, batteries can start to not hold their charge, motors can become weak from use/wear, the mechanical components can be seizing from hair/debri trapped around them making shaver work harder(overheating motor/battery), chargers can fail, internal gears can wear and lubrication can break down. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.amazon.com/Panasonic-WES9013...
这个答案有帮助吗?
得分 2
添加一条评论
Make sure that the battery is charging and operating properly. If the battery is not the problem then you may want to check the razor head for hair buildup. The razor will not shave as well if it has too much hair inside the head. If it is clean and the battery is charged, then it may be time to replace your motor
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew Trainor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 807
