跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
MacBook will not boot but will charge
I few days ago my macbook stopped turning on. When I hit the power button I get absolutely no response. Nothing from the LEDs, no fans, the harddrive does nothing in short the thing is completely unresponsive. The odd thing about this is that the battery is fine and the charger light comes on. I'm hoping it's just the power button, in which case I could just replace the upper case. Is there a way to test this? Could I remove the upper case and short the thing on? Or does this sound like a logic board issue? Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I found this pic for you, hope it helps:
Won't power on even after replacing logic board.
这个答案有帮助吗?
得分 3
1条评论:
Thank you! It took my a while to get a #000 Philips but that was exactly what I was looking for.
完成的
添加一条评论
添加你的答案
Areaman 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,475
