跳转到主内容
加入维修社区 - 创建账户
Released in 2013 Model number: ONETOUCH 7024W FCC ID: RAD386
Why isn't my touch screen working at all? I even hard reset it 10 time
Why isn't my touch screen working at all? I even hard reset it 10 times .. Now it starts up like a brand new device, but the touchscreen is nonresponsive .. Can someone please help me out. Alcatel one touch fierce 5054n
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
It sounds like the digitizer might be bad. From the teardown guide on the device page I suspect the digitizer may be in the LCD display. There is no guide for it as yet but the teardown might help.
Alcatel One Touch Fierce Teardown
完成的
添加一条评论
1个答案
已选择的解决方案
There are 3 possibilities
a) Digitizer went bad. -- you would replace the digitizer to fix this. Follow the iFixit tear down guide to replace the digitizer. Normally its easier to replace the LCD + Digitizer at the same time.
b) Digitizer cable is loose. -- Follow the iFixit tear down guide to open up the phone and check the cable.
c) Logic board is bad. -- Follow the iFixit tear down guide to open the phone up to change the logic board. However, if it comes down to this, you should look to get a new phone.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Westlee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 947
