跳转到主内容
The HP Probook 4530s is from a line of business notebooks manufactured by Hewlett-Packard (HP). It is from the S-Series (standard series), consisting of Intel powered screens.
13 个问题 查看全部
Windows Boots Up But Not BIOS
HP Probook 4530s
Windows 10 Home 64 bit, Insider Preview 15063 (rs2_release)
Core i3 2310M
8GB RAM
120 SSD for windows, 320 HDD
BIOS F.61
Windows boots up fine everytime. Very long time since i went into bios settings, i wanted to see if boot from usb option was on, and on startup when i press esc key or any function keys to get into bios settings, the screen goes black, hard disk light turns on and remains on, caps lock light starts blinking, i don't have num lk key.
I reinstalled bios and nothing changed. My battery is weak, if that matters, a warning is shown on boot up.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
HI:
I think you have a UEFI (bios) not the same as the bios is on the motherboard I a chip and the UEFI is on the hard drive but built to operate like.
watch this video and it will show you some answers,
Press F2 for first screen then ESC
https://www.youtube.com/watch?v=cp7fhjGO...
Good luck
这个答案有帮助吗?
得分 0
3条评论:
No I checked, I have legacy bios. Even if I do have UEFI its menu should open.
完成的
Yes the motherboard has a bios but to get to the program to change the settings is on your hard drive. I went to the machine's web page and looked plus I sent you a video link of the same machine being booted as I described.
Yes the menu should come up. I hope you are being fast enough to press your keys. With power down then boot start your key strokes immediately.
If you have reinstalled the bios it just could be how fast you try...
Good Luck
完成的
Pressing the keys is what brings up the black screen.
And like in the video i could get into the bios settings before.
完成的
添加一条评论
添加你的答案
Jamal Tariq 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 3,193
