跳转到主内容
MacBook Pro带有15寸屏幕的型号
8251 个问题 查看全部
Why is my MacBook Pro restarting all the time?
My mid 2012 MacBook Pro 15" keeps shutting down and restarting. I changed/upgraded ram cards from 2 gb each to 4 gb each, and put in a brand new solid state drive because I read quite a lot of articles and forums that state that would stop the problem. It is not getting hot. I have reset PRAM, SMC, and NVRAM. If you need, I have saved the most recent panic report. I am at a loss here, please someone help for I don't have the money to buy a brand new MacBook Pro. Than k you in advance. ~Andy
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
I called apple and determined it is my GPU that is causing the issue. The only way to replace it is to replace the logic board. (which is very costly!) :( Guess I have to just deal with it or get a new Mac.
这个答案有帮助吗?
得分 0
1条评论:
See it is the gpu. Since its the gpu using gfxcardstatus will fix it. Ive done it before and it worked for that other guy. Go back to el cap and see if it works.
完成的
添加一条评论
is it kernel panicing or shutting off. If it kernel panics, Check [http://this|GPU issues, please help?] for the answer that may help. gfxcardstatus is the program you would want to test.
Hope this helps and good luck fixing!
这个答案有帮助吗?
得分 0
10条评论:
I have tried to use gfxcardstatus but it says that I am "using a system that does not support gfxcardstatus."
Also, the OS is OSX Sierra.
完成的
You need el capitan to run it. Im pretty sure this could be your issue. Does it Kernel panic? or just shut off
完成的
Yes, it kernel panics. I unchecked the box to disable GPU Switching. Let's see if that works.
完成的
@aewing Think it should. lemme know if it works then
完成的
显示更多的5条评论
添加一条评论
What OS are you running?
这个答案有帮助吗?
得分 0
1条评论:
I am using OSX Sierra.
完成的
添加一条评论
添加你的答案
Andrew Ewing 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,150
