跳转到主内容
加入维修社区 - 创建账户
Popular clothes dryer series by Kenmore.
Dryer won't stay running and smells like burning
I push the button on my kenmore 80 series dryer dryer and it will stay on while I am pushing it but quits after 30 sec and smells like a burning smell. We took off the back a nd cleaned it and replaced the door latch because it was bad but now I'm not sure what to replace.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
My dryer don't stay when I push switch
完成的
@alvaroregalado49
What is the model number of the dryer?
Do you mean that it won't start at all or that it starts but then doesn't keep running?
If it starts OK how long does it run for before it stops?
完成的
添加一条评论
1个答案
最有帮助的答案
@renee5888 , Renee, You have already completed an important step by cleaning the venting on machine, did you try running with vent hose off. It is possible it is a over heating/faulty motor runs for a bit and overheat/thermal switch shuts it down. Links below may also help in diagnosing and repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=yEQSCJ89...
https://www.youtube.com/watch?v=autfvjoM...
这个答案有帮助吗?
得分 2
2条评论:
Thanks! I did try without dryer hose on but it still didn't work. I'll watch these videos but I was hoping it wasn't motor. :(
完成的
Renee, maybe check all the connections also, in case one or more working itself loose or a bad/pinched wire arcing. Thanks for replying back.
完成的
添加一条评论
添加你的答案
Renee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 8,183
