跳转到主内容
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
120 个问题 查看全部
Samsung galaxy tab 3. Not charging
Tab 3 not overcharged. I have followed videos and advise and have disconnected and reconnected the battery from the board and tried to hold the sequence of different button to get it charging etc.. nothing is happening .... charger clicks in and not loose. Tried many different chargers and sockets and even tried the trickle charge from a pc ... help please
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
I was planning on buying a new battery, however, following you advice, pling, it's charging again!!! Well done and thank you!!
完成的
i just put in a new battery
完成的
添加一条评论
3个答案
已选择的解决方案
@lozc ,Laurac , have you replaced the battery, as it could be faulty. A lot of forums feel a factory reset can fix this type of issue, read and follow the steps in the first link below if you would like to try, all data not backed up will be lost.
Reset did not work, The battery, cable/charger, charge port or charging IC may be faulty damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connections and reconnect/install battery, still not charging battery probably faulty or the charging IC may be bad. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board (2nd link)and the heat generated could cause further damage if not very careful. Good luck.
https://www.androidpit.com/forum/602119/...
https://www.youtube.com/watch?v=0fcqUXtF...
这个答案有帮助吗?
得分 1
1条评论:
My Samsung Galaxy Tab 3 Lite 7.0 has a broken charger port, could I take the charger port out of a Galaxy S3 that I have and put it in my Samsung Galaxy Tab 3 Lite 7.0?
完成的
添加一条评论
最有帮助的答案
read this on this site and it worked for my tab 3
Disconnect charger
Hold power button and volume up button for 30 seconds
Keep holding buttons while plugging in charger
Hold buttons for another 30 secs
Release power button keeping volume button pressed
Tab starts to charge
这个答案有帮助吗?
得分 10
10条评论:
Thank you so, so much, honestly!
I was about to give up and send it to a repairing center when I found your solution, and it worked!
完成的
GOSH , this happen before and I had to pay for repairs ... happened again , this trick resolved it. thank you kind sir/madam... any idea as to why this does happen to these tabs ?
完成的
I've tried this, but it shows like it's about to charge then goes blank. Not charging.
完成的
@gabsizaguirre yay glad it helped!
@adhir i really don't know, only found out that this is a common problem with this model
完成的
Thankyou - just followed the suggestion of Power/Volume buttons and it sorted my wife’s Tablet out .. cheers.
完成的
显示更多的5条评论
添加一条评论
Didnt work. Still says 100% charged tho …and works great while connected to power
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Laurac 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 40
总计 40,809
