跳转到主内容
Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
31 个问题 查看全部
im needing to replace a couple motors in my dx-2.
I'm trying to find any info I can on the motors in my drone. I have a Sharper Image DX-2. I know at least one of them are bad. I have been looking high and low for specification. But to no avail. If someone could please help point me in the right direction, that would be awesome!!!! Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
7条评论
Hi,
Is there a part number stamped on the motor at all?
If so you could try searching online using the number 'only', (initially do not add anything else to the search term), if no results add Sharper Image or DX2)
完成的
Me too but I think I do need one thanks
1 propeller doesn't work
完成的
I need a brand new drone motors dor my dx-2 drone where can I buy them?
完成的
Somebody know where i can buy? The ebay link doesnt work anymore
完成的
one of my props is not spinning and i need sm hlp
完成的
显示更多的2条评论
添加一条评论
2个答案
已选择的解决方案
Hi @gnovakovski ,
Did you try calling the Customer Support number and asking them what parts are available from them?
This is from the User Guide for your drone:
CUSTOMER SERVICE
(800) 374-2744
Before calling please locate the 10-digit code printed on the back of your remote
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Here you go.
3 motors and a remote for $15 USD
http://www.ebay.com/itm/Sharper-Image-DX...
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
John Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 4,687
