跳转到主内容
The Kindle's big brother, the DX sports a large 9.7" e-ink display that reads like real paper even in bright sunlight.
15 个问题 查看全部
Is there any way to fix a broken button?
Is there any way to fix a button that has physically broken in half? It is the main toggle button between the menu and back button on the Kindle DX. If it cannot be fixed, is there a new model that would be recommended that is similar. I have very poor eyesight and this model has been very good for me because I can make the font very large and it is not backlit.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
This is a very common problem according to the many DIY "fixes" posted on the internet. Amazon WILL NOT issue a recall or a repair for it.
完成的
添加一条评论
1个答案
已选择的解决方案
Heather Neilson , The button should be replaceable. The first link below shows how to disassemble the device to access the button to change. The other 2 links may have a replacement button for you or you can also do a search using your make and model replacement buttons. If not wanting to tackle the repair pop into a good local cell/computer repair shop, have them take a look and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.rapidrepair.com/Merchant2/mer...
http://www.powerbookmedic.com/xcart1/hom...
http://www.powerbookmedic.com/Amazon-Kin...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Heather Neilson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 19
总计 1,052
