Where is the knock sensor located
I need to know where is located the knock sensor for honda accord 2001 vtec motor.
Henrry Quintanilla , From under the car you will see it bolted into the 2.3 engine by the oil filter/above. The link below may help. Good luck.
这个答案有帮助吗?
Very helpful! Love the camaro pic.
Ineed too know where is located the knock sensor for a honda accord 1998
这个答案有帮助吗?
pretty sure 98 to 02 are the same
It's located on the rear of your motor right above your oil filter. For better clearance remove the oil filter and you we be able to see it from under the car
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 27
总计 10,323
