跳转到主内容
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 个问题 查看全部
new lcd have a gray and black vertical lines
Hello. I bought on Ebay an lcd for Galaxy s3 i9305 and the lcd worked fine for an hour, then the picture was gone and the black and gray verical moving lines appeard. The touch still workes just the picture is gone. The salesman tell me that i should clean a flexcable with alcohol and leave it charging for a few hours, but i did that and still the same. I tried 3 differend motherboards to confirm that the lcd is the problem and on all 3 are the same vertical lines. Does anybody know what is here the problem. The lcd is not OEM so i probably canot expect that it will ever worked again. Thank you, Gorazd.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Gorazd Preloznik , Return the the LCD as defective for replacement/refund. Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Gorazd Preloznik 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 50
