vechicle too low sign comes on
snow1544 , You have a air suspension fault. Have scanned for codes and checked for fault by a good technician. If you can hear the compressor run and the vehicle will not lift then there's an obvious leak, possibly air line, air bag, or maybe leaking O-rings at the bag solenoids. It could also be caused by an electronic glitch; ride height sensor, etc.
May get some info. from links below. Good luck.
http://www.jaguarforums.com/forum/xj-xj6...
这个答案有帮助吗?
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 39
Why is it doing that?
由 Conor Bailey 完成的
