跳转到主内容
Coconut Battery says Battery Failure Yes (83) with new battery
I am getting a battery failure #83 with a new battery in coconut, otherwise it's working.
Is the new battery defect and should be changed?
Update (03/16/2017)
here it is
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
19条评论:
I have written an email to Chris Sinai (from Coconut-flavor) and requested help from the horses mouth>
完成的
Thanks, that's kind!
完成的
Chris never responded, sorry. But I also got in a new battery this week with this same failure. The battery only had 53% of the maximum capacity, weighed about half of what a normal one did. I got my money back and the supplier didn't even want it back.
完成的
ok, no problem, just did it myself as i was thinking of returning the battery. yours sounds like a rip off. mine was not the cheapest on the market but also not the most expensive, and i am quite satisfied with it. would have returned it back also if it would have been like yours.
完成的
Thats definitely an aftermarket battery. That means ur battery has 83% of life left with only one load cycle. Usually u should have over 200 cycles on a OEM battery. I would try to get my money back or trade it for a new one
完成的
显示更多的14条评论
添加一条评论
1个答案
It is just fine. It happens when u get an aftermarket battery.
这个答案有帮助吗?
得分 0
8条评论:
@sherlock_holmes ‘It is a capital mistake to theorize before one has data. Insensibly one begins to twist facts to suit theories, instead of theories to suit facts.’ -A Scandal in Bohemia
Can you back that statement up?
完成的
@sherlock_holmes sorry, your answers are partially complete nonsense. i want to point out one of your first answers: "Thats definitely an aftermarket battery. That means ur battery has 83% of life left with only one load cycle. Usually u should have over 200 cycles on a OEM battery. I would try to get my money back or trade it for a new one
16.03.2017 von Lord Vader's Finest Rocketeers " error code 83 has nothing to do with life left. you were mixing up % with codes and so on. please think twice and write nothing before nonsense. nethertheless thanks for your well-mentioned help.
完成的
What is the designed capacity have? And why was the answers and comments sent to just comments?
完成的
Is the bottom picture of the old battery?
完成的
Because there is an error code for that as well. Sorry btw. That was my bad. I don't know what I was thinking
完成的
显示更多的3条评论
添加一条评论
添加你的答案
heribert weber 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 11
总计 4,966
