I installed a new SSD and disk utility is not recognizing it.
Steps I've done so far.
- Erase the SSD and reformatted to Mac journal.
- Install OS Mountain Lion from internet recovery.
- Installed my time machine backup to the SSD from an external hard rive.
- Unplugged and plugged in the SSD to check if it was seated properly.
Everything was working fine until I opened the laptop from standby then it froze and shut off.
Now all it does when the computer boots up is go to a black screen with the folder/question mark. If I boot it up in recovery mode it only goes to internet recovery and does not show the SSD.
Any advice?
Who's SSD did you put in? A few pics of the labels on your original and replacement SSD's would help.
由 Dan 完成的
I took out the original SSD that was installed in the MacBook Air from Apple and installed an OWC
240GB Aura SSD / Flash Internal Drive Upgrade
for Mid-2013 and Later MacBook Air and MacBook Pro with Retina display.
由 chris.stick 完成的
Did you get the Envoy enclosure with it?
由 mayer 完成的
The only thing the envoy inside the box said was that this SSD was incompatable with Boot Camp Assist.
由 chris.stick 完成的
What is throwing me off about this is the new SSD worked perfectly for hours after I installed it. It only stopped working after I put the computer to sleep and started it up again after sitting overnight.
由 chris.stick 完成的
显示更多的2条评论
