跳转到主内容
Scientific calculator by Casio with 252 functions and full dot matrix display. It also features a Replay function and seven variable memory.
Why is my calculator showing a decimal as the answer?
Whenever I use my calculator, and do an equation, for an example, 2+2. It would always give a decimal as the answer when clearly it is not. For 2+2, it says 4.0 instead of 4. For 9.2+1.2, it says 1.0 instead of 10.4. I really don't know what to do because I have finals coming up soon.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
最有帮助的答案
usually it is shift + 9 to reset all settings on a calculator to default
这个答案有帮助吗?
得分 2
添加一条评论
Try SHIFT, then MODE [SETUP], looking through the menu and selecting the mode you want.
这个答案有帮助吗?
得分 1
2条评论:
How do I get a dot instead of a comma in my iPhone calculator?
完成的
Caoimhe, please create a new question on this in the main Q&A page. This specific question is on the Casio fx-82ES, so your question will not bee seen by our community.
完成的
添加一条评论
just press shift 9, it puts all the settings back to normal
这个答案有帮助吗?
得分 0
添加一条评论
Yess this happend to me and the answer in press shift + 9 or shift , mode , 3 , = and again =
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vanessa Mendis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 28
总计 15,495
