跳转到主内容
Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
What's wrong with this thing?
I literally just bought the Vinking Pro (less than 2 hrs ago), after following all the initial set up prompts it went to a black screen. You can see the symbols showing the wifi connection and battery life in the upper right hand corner, but can't do anything but use the power button to shut it off. If you try turning it on again, you see a flash of some sort of wallpaper but then it goes black again. What's wrong with this thing?!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I just did a factory reset and it gave me 4 options after, I tried to just go to the "proceed to Windows 10" button but the only one that would would work was power off device. Now when I turn it on RCA comes on the screen but nothing else happens.
完成的
添加一条评论
3个答案
已选择的解决方案
@nadal79 not sure where you bought it from but this " you see a flash of some sort of wallpaper but then it goes black " sounds like a bad LCD or a bad signal issue. I'd return it to where you got it from.
这个答案有帮助吗?
得分 2
添加一条评论
It's not turning on but when I press the button a dull light show's
这个答案有帮助吗?
得分 1
添加一条评论
How to fix the prong section of connectible key board? Is there piece tat you can buy that just has the prongs? Only one prong of mine is missing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nita 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 583
