跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Dent on earpiece Speaker Grill
I recently dropped my iphone 7 and it has a little dent in the earpiece speaker grill. can it be repaired or replaced only the speaker grill with new parts ? or it has to be replaced along with the screen because the earpice grill comes in one piece with the screen ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
To Bryant's point, yes, any action here will make the phone less water resistant. Having never been disasembled, I would consider the above iPhone to be “decently water resistant.” As soon as the top assembly of the phone is popped of the metal frame, the adhesive between the two halves will stretch and tear, resulting in the phone being “ barely water resistant at all if immediately reassembled.
This is why is good to replace the adhesive with a new gasket after completely stripping the old glue. If you really remove ALL the old adhesive residue from the frame and screen, use a new gasket that has no imperfections, avoid fingerprint oil contact on either side, and use a little heat/compression after closing, the phone can be made “decently water resistant” again. Precut glue strips for the frame are easy to find for a couple dollars.
However, to replace the metal grill just behind the screen cover glass, several layers of adhered bariers in front of the speaker with near to be peaked away. I do not think if it's practical to make an iPhone 7 earpiece speaker hole water resistant again, at least not as a DIY project. There are too many layers and buying the correct precut glue strips used in the original assembly may not be possible. So if you feel the need to replace the grill, know that it would be for cosmetic reasons only and the phone will be more easily compromised by liquid if submerged.
这个答案有帮助吗?
得分 1
添加一条评论
The speaker grill comes with the screen, however, it is removable, if you are carefull. to do this, i apply low heat to it, and remove it with a sharpened spudger. (a vinyl pry tool)
(Follow the earspeaker replacement steps to get to the point where you can remove it.)
Take extreme care not to scratch the paint on the glass.
Its a cheap as dirt piece. so have atter.
这个答案有帮助吗?
得分 0
1条评论:
Would this cause the phone to no longer be water resistant?
完成的
添加一条评论
添加你的答案
Firman Muhtadi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,633
