跳转到主内容
Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
494 个问题 查看全部
Golf car runs when cold after warming up quits moving forward or rever
My ez go gas golf cart runs fine when cold after it warms up its like the trans went out wont go in forward or reverse at first it would still run in reverse for awhile about 5 more mins and then nothing in either direction .After cooling down overnight then it would run fine for about 20-30 mins and then quit going again .
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I have the same problem and I have replaced the belt and clutches and the problem is still there.I even changed cdi box new rear end carb and accelerator cable new coil..Nobody can figure this out..ive spent over 1100.00 trying to solve issue.
完成的
添加一条评论
1个答案
已选择的解决方案
@musicman4577 , billy, Sounds like a drive belt or clutch issue, check the belt for being worn, when a belt gets to a certain thickness(worn) it will cease to work when warm or may not work at all, replace the belt or if adjustable, adjust. Check your clutch for proper function and wear. Check the links below to help trouble shoot your cart 2nd link is the service manual for gas powered carts. Good luck.
http://www.golfcarcatalog.com/golf-cart-...
http://www.specialtycartz.com/pdf/ezgo_g...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
billy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 19
总计 2,091
