Why didn't the time reset to daylight savings time?
How to reset the time to Daylight savings time?
In settings, change time zone from "America/Eastern Standard Time" to "US/Eastern Standard Time".
这个答案有帮助吗?
This did not work on my Alexa Show. It responded "on what device?"
Mine was set to Mountain Tme zone, Dawson Creek, I re chose Mountain Time zone, Edmonton, all good now,!
Thank you so much I've tried everything this worked 💪
Go into Alexa's settings and change location from "America" to "US." I just fixed mine today doing the same thing.
这个答案有帮助吗?
Thanks! That did it.
Mine was already set correctly to US. But I did it again to be sure. My clock did not reset to DST. It's still an hour late. HELP!
Mine is the same way. I went into device settings>Time zone and the time zone is set correctly however it is not updating the time on the clock. Anyone else have any ideas?
Same issue for Amazon Smart Oven. Verified set to US central. Tried toggling to different countries/time zones - no luck. Happened after DST switch.
Where is your location set to? Daylight saving is different around the world. America was last night (12 March) and the UK is in a few weeks (26 March) etc.
这个答案有帮助吗?
I'm on the east coast, so I set the time zone to Atlantic to temporarily fix it until I can find a more permanent solution.
这个答案有帮助吗?
In Alexa ->setting select Device option then choose Date/Time. If your Automatic Time Zone is ON then It will select automatically your time according to place by using Wi-Fi network. If you want to choose time zone manually you can OFF Automatic Time Zone and select Time Zone.
这个答案有帮助吗?
What worked for me is going to settings date&time and choose a time zone an hour ahead. The go back to your time zone and it updates. Looks like a bug to me
这个答案有帮助吗?
For anyone in the UK/Ireland, I finally fixed this issue by disconnecting the echo dot from the WiFi and reconnected it and it fixed the time!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 66
总计 21,429
2条评论
im having this problem it refuses to let me choose my time zone its always an hour a head and nothing i do fixes it when just yesterday it was working perfectly fine
由 blackunseen 完成的
Why do you assume this is the problem. For some in the Mountain standard time zone the problem could simply be that they have Arizona selected instead of Boise. Arizona doesn't switch to DST. I don't even see an america or US only the names if cities.
由 kimballclark730am 完成的
