跳转到主内容
Hands-free voice-activated device by Amazon powered by Alexa Voice Service. Model S04WQR.
Why didn't the time reset to daylight savings time?
How to reset the time to Daylight savings time?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
im having this problem it refuses to let me choose my time zone its always an hour a head and nothing i do fixes it when just yesterday it was working perfectly fine
完成的
Why do you assume this is the problem. For some in the Mountain standard time zone the problem could simply be that they have Arizona selected instead of Boise. Arizona doesn't switch to DST. I don't even see an america or US only the names if cities.
完成的
添加一条评论
8个答案
已选择的解决方案
In settings, change time zone from "America/Eastern Standard Time" to "US/Eastern Standard Time".
这个答案有帮助吗?
得分 5
3条评论:
This did not work on my Alexa Show. It responded "on what device?"
完成的
Mine was set to Mountain Tme zone, Dawson Creek, I re chose Mountain Time zone, Edmonton, all good now,!
完成的
Thank you so much I've tried everything this worked 💪
完成的
添加一条评论
Go into Alexa's settings and change location from "America" to "US." I just fixed mine today doing the same thing.
这个答案有帮助吗?
得分 1
4条评论:
Thanks! That did it.
完成的
Mine was already set correctly to US. But I did it again to be sure. My clock did not reset to DST. It's still an hour late. HELP!
完成的
Mine is the same way. I went into device settings>Time zone and the time zone is set correctly however it is not updating the time on the clock. Anyone else have any ideas?
完成的
Same issue for Amazon Smart Oven. Verified set to US central. Tried toggling to different countries/time zones - no luck. Happened after DST switch.
完成的
添加一条评论
Where is your location set to? Daylight saving is different around the world. America was last night (12 March) and the UK is in a few weeks (26 March) etc.
这个答案有帮助吗?
得分 0
添加一条评论
I'm on the east coast, so I set the time zone to Atlantic to temporarily fix it until I can find a more permanent solution.
这个答案有帮助吗?
得分 0
添加一条评论
In Alexa ->setting select Device option then choose Date/Time. If your Automatic Time Zone is ON then It will select automatically your time according to place by using Wi-Fi network. If you want to choose time zone manually you can OFF Automatic Time Zone and select Time Zone.
这个答案有帮助吗?
得分 0
添加一条评论
Go to Alexa ‘s Settings and change location that you want to change.
这个答案有帮助吗?
得分 0
添加一条评论
What worked for me is going to settings date&time and choose a time zone an hour ahead. The go back to your time zone and it updates. Looks like a bug to me
这个答案有帮助吗?
得分 0
添加一条评论
For anyone in the UK/Ireland, I finally fixed this issue by disconnecting the echo dot from the WiFi and reconnected it and it fixed the time!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Williaim King 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 66
总计 21,462
