跳转到主内容
加入维修社区 - 创建账户
Z30 是 BlackBerry 于2013年秋季发布的一款触屏智能手机。
earphone socket not working
I bought my BlackBerry z30 before 5 months earphone jack is not working. How can I solve this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@balanagaraju , bala , Try a reset, Press and hold volume up and down button simultaneously and letting the phone restart or Press and hold the power button till the phone restarts.
Try a different compatible set of earphones(a lot of aftermarket type may not work), look inside the jack for dust/lint/etc., pick out any you see and then blow out with canned compressed air. Go into your phones setting to be sure not muted,etc. if alllooks good possibly the jack is faulty and will need replaced. If only 5 months old return for repair/replacement/refund. If not worried about warranty you could also dissmantle the phone(link below) and check and clean the connection/check for damage, reassemble and try. Good luck.
BlackBerry Z30 主板更换
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
bala 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 984
