跳转到主内容
Keurig 咖啡机维修指南和支持,包括 K-Cup 系统。
495 个问题 查看全部
Only brews full cup when no k- cup is inserted
I recently descaled my keurig and also cleaned the needle with a paperclip. It will brew a full cup only when there is nothing in the cup holder. Once I insert a k- cup or a reusable cup it only Brewstandings a half a cup at best.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Sounds like your Keurig is stuck in the half-cup brew setting.
When you brew with the k-cup inserted, some of that water is used to saturate the grounds in the k-cup, so you would get less "liquid output" with a k-cup inserted than with no k-cup inserted.
Try switching between full cup and half cup setting with no k-cup installed. Is there a noticeable difference in the output from the full and half setting? If not, then it is stuck in half setting.
Look at this post, to help: only brews small cups regardless of setting
这个答案有帮助吗?
得分 0
3条评论:
You know the last time I had a Keurig I had the same problem so I waited about 78 years thought maybe the technology would improve. So I got a small model and it still does the same thing why even produce a product that is gonna do this kind of thing it's ridiculous.
完成的
Did you ever get this fixed? I had the same issue with old machine after couple years. Replaced the machine and now same issue after couple years.
完成的
I bought a kuerig 5 months ago, stopped brewing full cups even after cleaning everything. Bought a new one & 1 week later doing the same thing!!! Brews full cup when there is no k-cup in it.
完成的
添加一条评论
添加你的答案
Mike Loia 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 64
总计 7,873
