跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Ambient light sensor not working
I purchased and installed an ifixit screen for my iPhone 6s, and the 3D Touch feature was so sensitive you couldn't use it, and the auto brightness would not work. If you set the brightness and locked the phone, it came back on at medium brightness every time. I received a replacement screen, and the 3D Touch works great, but the ambient light sensor is still not working. Same issue with the brightness returning at 50% regardless of where you set it. I got the screen and digitizer as an assembly so the accessories (other than the home button) were already installed. All other features including the proximity sensor and front camera work fine. Help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
Try replacing the front camera flex with the original one from your broken screen. Use this guide.
这个答案有帮助吗?
得分 2
2条评论:
Thanks Minho. Unfortunately I don't have the original. I should have scavenged the original for parts but I put too much faith in the replacement!
完成的
This solution DOES NOT WORK!!
I purchased an iFixit replacement screen, and even after replacing the front camera flex with the original, it still does not work.
The iOS is detecting that the screen is NOT ORIGINAL and disables the Auto Brightness feature.
完成的
添加一条评论
Well.... unfortunately i have the same problem. But it shouldn`t be the general doing for each display replacement. Luckily i have the original parts. :-/
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issue and I also can‘t use the old cable(Microphone is Brocken). I ordered 10 cable from different shops and all is workout only the ambient light. Still little under middle level. If I plug in temporarily the original it works fine. It seems a calibration is needed but all tutorials what I find didn’t work. If someone has a solution, please share it. Thanks
Greetings from Germany
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dusty Wall 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 5
总计 1,526
