Why does my center channel not work?
My Pioneer VSX-821K AVR center channel output suddenly stopped functioning. I tried changing out the speaker wire without any benefit. I also tested the center speaker from other channels and it functions well. I've tried other speakers as well and it's definitely the channel out. Checked over all AVR settings, have the center channel still on and tried it from 0 to +10db without any help. When testing the speaker with the on screen display, the pink noise from the center channel is significantly quieter and crackles instead of having a clear output sound. The center channel is extremely muffled and barely audible when using 5.1 output. Volt meter shows equal output and resistance from the center channel as well. Not really sure what else to do to troubleshoot it other than opening up the receiver itself and tracing the soldering for the central channel from the output.. Any suggestions? Thanks!
2条评论
@kxn58 "Volt meter shows equal output" what voltage do you see?
由 oldturkey03 完成的
Did your receiver come with a sourround audio tester mic? If so, have you tested it?
由 George A. 完成的
