跳转到主内容
2014年十一月至2016年初期间,使用Microsoft Lumia品牌发布手机的维修指南。在2014年之前,Lumia品牌也曾被Nokia使用。
Why won't my phone charge
The phone seems to work but it won't charge.
Any suggestions
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@flumixed , Lesley, The battery, cable/charger or charge port may be faulty damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connections and reconnect/install battery, still not charging battery probably faulty. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a mini USB attached to the board. The last link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
https://www.youtube.com/watch?v=OsHHpADN...
https://www.youtube.com/watch?v=biqmwsys...
https://www.amazon.co.uk/Microsoft-550-6...
这个答案有帮助吗?
得分 2
1条评论:
Thank you so much for your detailed answer.I will let you know how I go.
完成的
添加一条评论
添加你的答案
lesley 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 109
