How to fix 1907FPc 19" LCD Monitor feet from tucking?
it is stuck in the bothom
RENX , Check to see if there are removable plastic caps covering up screws that could be tightened to stop the screen from tilting. I had a stand that would keep tilting down on me and I wrapped a large an elastic around the hinged joint giving the problem and it worked. Good luck.
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 19
总计 258
1条评论
What is "tucking" and can you elaborate more on your problem
由 Cameron 完成的
