跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Wifi - Periodic "No internet connection", Reboot to Fix
Periodically, my iPhone 5s will lose its connection to Wifi. When I go into Settings, it recognizes my Wifi network, and is trying to automatically connect to it (because it is a known network). However, underneath the network name the phone displays "No Internet Connection", and will never connect. After rebooting, the phone will connect to Wifi when I unlock the phone and go back to the wifi menu in settings (It will display LTE until I physically go into the wifi menu), but the process will start all over again after a while (e.g. 24 hours).
There has been no water damage or drops. Phone is in good condition. The wifi network is working normally, because other devices are connected and receiving regular internet service (e.g. Computers, amazon echo, apple TV, etc. - devices without cellular service).
Any thoughts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
First of all, try to restore it through iTunes. If the problem is still there then you would probably have to troubleshoot it on a hard-ware level. As far as I know it's most likely something faulty on the motherboard when it comes to these wifi "sometimes" problems. If it had to do with the antenna the problem would most likely always be there.
Also, if you restore it through iTunes and it turns gray then its definitely something related to the wifi-chip.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tim D 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 484
