跳转到主内容
加入维修社区 - 创建账户
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
It just doesn't make sense!
Custy brought in iPad mini 2. She said she did the repair herself, worked fine for a year and a half. Then after updating the home button stopped working. When I tested it at first, the power button isn't working, it charges but the display won't come on, home button still doesn't work. Decided to put a new glass digitizer on, put it into dfu, works just fine! Except when plugged in, at first it says charging, then after a second or two, says not charging
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Or a bad charging IC.
完成的
Yeah, but does all that other stuff work? The power button? To simply turn it off and on? Sorry, sleep/wake? Also, everything works great, with the new display
完成的
添加一条评论
1个答案
已选择的解决方案
If you troubleshooted all the rest, power cable, charger, as I believe you did, there isn't much else left between power and the battery, you have the charging port, the solder joints where the port joins logic board and the Ic(s).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
iMedic 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 152
