跳转到主内容
加入维修社区 - 创建账户
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
Gas leaking from engine?
Hey everyone. I had been smelling gas coming from my 2005 cavalier. I just pulled out of my parking spot and noticed a sizable amount of gas on the ground. I haven't popped the hood yet it's 9 degrees here but just wanted some input. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@westhavensean,Sean, It will probably be a rusted out/damaged fuel line or connection. You really should discontinue/restrict your driving until repaired as it could be a fire hazard waiting to happen if you do not wish to address the repair yourself. Have a reputable shop have a look and estimate repair.Good luck.
这个答案有帮助吗?
得分 2
1条评论:
I'm having the same problem with my 2005 Cavalier gas in the air box I had a crack in the side of my fuel pressure regulator line thought maybe that was the problem fixed it still doing it fixed another vacuum line thought it might help but it didn't so me too and trying to figure out where the hell all this gas coming from
完成的
添加一条评论
添加你的答案
Sean Rasmussen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 781
