跳转到主内容
加入维修社区 - 创建账户
iPad Mini4 Wi-Fi版型号A1538指南 。iPad Mini3的后继版本iPad Mini4 发布于2015年9月9日。
Home button gasket compatability
IPAD mini 4. I can't find a direct replacement. Are there other MINI's that use the same gasket?
The entire assembly came apart when replacing the LCD / Digitizer.
What I have looks like a shim that was glued to the glass, followed by what looks like the rubber gasket.
If and when I find the part, does it reassemble as follows?
1) attach shim washer to glass
2) attach rubber to shim.
3)attach button to rubber.
4) glue down bracket.
I'm hoping if there is a replacement part it includes the shim and rubber as one.
Thank you.... Everyone!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
The IPAD AIR 2 is compatable and available from multiple sources.
完成的
tjmurf, Yes the link I provided says, Replacement for iPad Air 2 / iPad Mini 4 / iPad Pro and would be available at multiple sources.
http://www.unionrepair.com/?subcats=Y&pc...
完成的
tjmurf, I am wondering if you received a satisfactory solution. I have found a source of Home Button, Bridge, Rubber Gasket and Shim all in one packet.
However, I am at a loss as to the correct method of fitting the gasket and shim and can find no instructions on-line. Any new ideas?
完成的
添加一条评论
1个答案
已选择的解决方案
tjmurf , Replacement gasket for IPAD mini 4 link below, verify correct for your model before placing order. 2nd and 3rd link may help in showing how button assy. Good luck.
https://www.youtube.com/watch?v=V0ViWDPB...
https://www.youtube.com/watch?v=6x1vBeCh...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
tjmurf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 586
