跳转到主内容
Small media streaming device that plugs directly into your TV's HDMI port. Originally released by Amazon in November 2014. The latest version comes with a voice-activated remote.
116 个问题 查看全部
Why aint my volume working on firestick. Does remote have a volume but
My volume works on tv but when I try to watch a movie on my Firestick i don't have volume. Does the remote have a volume button? What could cause this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 12
4条评论
I'm experiencing the same issue, Melissa. at 20 on regular TV, my Samsung TV is quite loud. watching a movie now using Amazon firestick, we have the volume at 50 and we can just barely hear it. if I find a real answer, I promise I will share. It's very frustrating!
完成的
Thxx helped me
完成的
Everything else works but my volume button
完成的
Thanks so much it worked for me.
完成的
添加一条评论
20个答案
最有帮助的答案
Okay, so I just had this issue. Hold down the home button until the settings option comes up. In settings go to “equipment control”. Go to “TV” and “change TV”. On screen prompts will walk you through from here. This was the issue for me. Hope this helps someone.
这个答案有帮助吗?
得分 21
10条评论:
Nope, none of the selections ar TV or Change TV.
完成的
I had the same problem, did all the steps and still nothing. What I did was unplug the TV for about 10 seconds and plugged it back in and BAM that fixed the problem. Not the fire stick but the tv itself. I couldn't even power my TV off, but now everything is back to normal.
完成的
how can I put volume in fire stick tv
完成的
Unplugging the TV worked for me, Thankyou
完成的
Thank you so much, it worked!!!
完成的
显示更多的5条评论
添加一条评论
I had this! Couldn’t control volume or power on/off with fire stick remote. Did everything said on here, even turned TV off for 10 seconds but still didn’t work. I solved this issue for me by taking out the batteries on the remote!! Literally opened the back & switched the batteries around (didn’t replace them) & power on/off worked as did volume control so could be the batteries need replacing soon - hope that helps anyone googling the issue & coming here :D
这个答案有帮助吗?
得分 8
11条评论:
Just tried that and it works. Thanks.
完成的
This worked!
完成的
I tried EVERYTHING and THIS was the only thing that worked!! Thank you
完成的
Been trying to find a solution for almost a year. Thanks!! It worked!!
完成的
That so random! It worked!!
完成的
显示更多的6条评论
添加一条评论
Go to settings -> Equipment control -> Manage Equipment -> TV -> Change TV
Follow what Firestick says and done.
这个答案有帮助吗?
得分 6
3条评论:
You had the perfect response! Thank you so much! Fixed it right away
完成的
This was easy to follow and so simple. Thank for your help. Too easy.
完成的
When I go to settings it doesn’t give me the TV option when I go to equipment control it just says equipment control automatic or manage equipment
完成的
添加一条评论
My problem was that during the TV/remote setup/config (Settings -> Equipment Control -> Manage Equipment -> Change TV) the only option that worked with the power and mute button wouldn’t work with the volume button. Volume up would not work at all, but the volume down would trigger the “AnyView Cast“ option for my HiSense TV.
I tired everything mentioned in this thread. The only thing that worked for me is this.
Take out the batteries from the Remote, Unplug Fire TV from the HDMI and power source and leave it off for 20 seconds. Plug the Fire TV back (HDMI and Power Source). Wait for the Fire TV device to boot. Once on the home screen, put the batteries back in the remote and press the Home button for 10 seconds (disregard the shortcut menu) your remote LED (top right) will now start blinking.
Wait for the blinking to stop and go to Settings -> Equipment Control -> Manage Equipment -> Change TV.
I followed the same configuration steps again but this time one of the combinations finally worked.
Now everything on my remote works.
这个答案有帮助吗?
得分 4
3条评论:
Yes it actually worked. Thanks
完成的
i am facing problem with power button not working and also volume up and volume down not working.....
完成的
It worked. Fantastic. Thanks.
完成的
添加一条评论
Finally solved my lack of volume control by changing where the Audio was being sent. To the TV not a Soundbar, since I didn’t have one. The TV had once been connected to one and who would have thought, duh! Just go to Settings, Equipment control, Advances settings, Volume control device.
这个答案有帮助吗?
得分 2
1条评论:
Thank you so much! This is what worked for me! I forgot all about our sound bar being connected!!
完成的
添加一条评论
My remote didn't work for volume or power on or off tried all these suggestions nothing seemed to be working then tried to put my TV as wrong brand (mine is alba changed it to bush) eT voila it now all works
这个答案有帮助吗?
得分 1
1条评论:
Cheers, I also have an Alba TV, selected bush and the IR frequency works.
完成的
添加一条评论
look around all over the stick to see if it has a volume or it went out or you need to turn the volume up on your phone
这个答案有帮助吗?
得分 0
1条评论:
we are asking about television volume, not phone volume.
完成的
添加一条评论
The 4 way navigation key is the volume control also. Press upper side for volume up and down side for volume down.
这个答案有帮助吗?
得分 0
添加一条评论
Get close to the TV and press volume button up or down, it doesn't really matter till you see the volume on the screen again and then you can go more further it will work.
这个答案有帮助吗?
得分 0
添加一条评论
I've tried everything. My volume on my remote still isn't working, nor the mute. Everything else does.
这个答案有帮助吗?
得分 0
2条评论:
Mine was doing the same thing. See my post below. Hope this helps.
完成的
I unplugged my tv and plugged it back it and it fixed, I have my tv on like 24/7 so it needs to reboot sometimes and then the remote starts working, it was the same when i use any remote, Fire Stick and regular remote.
完成的
添加一条评论
Open settings >> equipment control >> check if it's set to automatic. If it's disable enable it and check if the issue is fixed.
这个答案有帮助吗?
得分 0
1条评论:
What if u dont have the option for equipment control?
完成的
添加一条评论
Press the home button, go to settings
Select equipment control, then select tv..
Next turn power off and wait 10 seconds to power back on. Answer the question it will ask (yes)
Then you're all set…….
Gino Latino from Dallas TX.
这个答案有帮助吗?
得分 0
添加一条评论
I am facing the same issue as well on my LG tv as well as TCL TV…. So pretty sure its not an issue with the tv but its with the
这个答案有帮助吗?
得分 0
添加一条评论
Unplugged the fire stick from HDMI2 and connected To the HDMI 1 port on Samsung TV. And it resolved the volume issue.
这个答案有帮助吗?
得分 0
添加一条评论
Try following these steps ( Date- 20th Oct 20)
Home - Equipment Control - Manage Equipment - TV - Infrared Options - IR Profile - Change IR Profile - Select your TV brand name - Home
Try now . It should work
Note:
(Name of your TV Brand will be displayed if you have selected correct brand during 1st setup of Fire Stick
Otherwise you may try selecting diff IR profiles and check which one works)
Thanks
Sachin Pokharkar
India.
这个答案有帮助吗?
得分 0
1条评论:
unpluged 4k tv for 10 secs. and back on. Volume control worked!!
完成的
添加一条评论
Just another possible solution:
This same problem was happening to me and I finally figured out that the bluetooth on my FireStick had connected itself to my AirPods that had been left out of their case. Once I put my AirPods back into their case, it worked just fine.
这个答案有帮助吗?
得分 0
添加一条评论
Thank you. It worked. Had to change to current tv I was using, it still had prior tv in settings.
这个答案有帮助吗?
得分 0
添加一条评论
If you hear volume when it starts up but not any other time, check to see if you have bluetooth headphones that might have connected. That was my issue, spent an hour till the headphones finally died and i saw the disconnected message.
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
The volume will not work
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Melissa Allen 将永远感激不已
浏览统计数据:
过去 24 小时: 13
过去 7 天: 98
过去 30 天: 476
总计 176,841
