跳转到主内容
there is no picture or video just loud fan
Push power button, chime sounds, but there is no picture or video on the display
I did PRAM RESET by Shut down the computer Waited 5 second then press
Command, Option, P, and R. You will need to hold these keys down simultaneously
I can Hear The HD Is trying turn On with Loud fan noices ...what should i do next?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
What happens when you connect to an external display?
完成的
how can can i connect xternal display ? do i special cable ?
完成的
添加一条评论
1个答案
已选择的解决方案
Here is a link to Apples check out procedure. Hope it helps you.
http://support.apple.com/kb/TS2094
这个答案有帮助吗?
得分 3
1条评论:
+ very nice link. also open it and check for corroded or swollen capacitors
完成的
添加一条评论
添加你的答案
lutaph 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 10
总计 2,733
