跳转到主内容
LG Power Tracfone, ran on Android's 5.0 Lollipop platform with a 4.5" FWVGA Display, Model (L22C).
How to bypass Mcaffe mobile security pin?
I found a lg power on eBay for 12 dollars, it has a cracked screen and has a pin lock for Mcaffe security. It says it has been pin locked. Is there an equivalent to Odin for LG? Or how to factory reset it to get rid of it? It has a clean esn.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
Hi @gigabit87898 ,
Is this what you want?
http://phonefirmwares.com/usa-lg-x-power...
这个答案有帮助吗?
得分 4
4条评论:
I need something like that, but that is not the same phone. What would I use to flash it? Could I use Odin?
完成的
Hi,
Here is a link to download the LG flash Tool.
Unfortunately I cannot find any kdz file (ROM) for your particular model. You may have better luck. I tried looking for LG L22C assuming that this is your model, sorry about the mix up before, missed the X only saw LG Power not LG X Power.
Here is a link to the page that tells what to do
http://lgflashtool.com/
Here is a link to the download page
Download link is in the middle of the page 3.1MB .zip file
http://lgflashtool.com/download/#.WLwT7t...
完成的
Do you think a rom from a lg leon would work? It is almost the same but the Leon is GSM and not cdma.
完成的
@gigabit87898 if it is GSM not CDMA do not try it. Exactly what phone do you have? I thought it is a LG Power as well....
完成的
添加一条评论
Sorry about the late answer, Gigabit. Just hold the power and down button until it gets to the boot options, select factory. Factory as in Factory reset. Initiate it.
Hope this helps.
这个答案有帮助吗?
得分 3
添加一条评论
Here is the link to download Lg Flash Tool
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Gigabit87898 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 4,147
