跳转到主内容
Samsung Gear S,设备型号SM-R750,是一台可以和你Android智能手机连接的智能手表。Samsung Gear S发布于2014年10月
20 个问题 查看全部
Why is my gear S does not pair?
I baught a gear s and i tried to pair it with my galaxy S6 and my device doesn't find it in gear maneger... i tried to pair t with another device and still have the same problem... i tried to format it and i updated it from samsung kies still have the same problem???!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
bara qubbeia , According to the list, link #1 below the phone should connect to galaxy S6 , maybe factory reset and follow instructions in link #2 or link #3. Still no go, return watch under warranty for replacement/refund. Good luck.
http://www.samsung.com/hk_en/mobile_comp...
http://techlife.samsung.com/pairing-gala...
http://samsungrumors.net/use-gear-s-andr...
这个答案有帮助吗?
得分 2
2条评论:
L Pfaff
Thank's for your answer but unfortunately still have the same problem
I think i will go to samsung store to check it....
完成的
bara qubbeia, Yes, while under warranty return to store, as the watch should pair for you. thanks for replying back, good luck with your watch.
完成的
添加一条评论
添加你的答案
bara qubbeia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 221
