跳转到主内容
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 个问题 查看全部
How to replace broken steam valve? Water only comes out of steam wand
We recently moved and our Starbucks Barista (SIN006) got jostled and the plastic 'mushroom' knob for the steam valve broke off. I can use a pliers to turn the knob but even when fully clockwise, hot water (but not steam) shoots out of the steam wand. I took the top off and I do not see any obvious damage. The little contact switch seems in good shape (I figure that must control whether water goes to the brew head or the steam wand, no?)
1. Am I right to assume that the problem -is- the steam valve assembly?
2. I loosened the nut that seems to secure the steam valve assembly to the brew head, but the steam valve assembly does not want to slide off. How do I remove it? Do I just need to force it or is there some other thing holding it in place?
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Try this link: http://www.partsguru.com/SaecoRioProfi.h...
It provides 3 videos on replacing the steam wand, valve, and boiler assemblies; which should be helpful for removing the steam valve assembly and troubleshooting the problem.
这个答案有帮助吗?
得分 1
7条评论:
Thanks, will watch closely. We literally -never- use the Steam Wand. Is there some way to simply -force- the water flow to the brew head without replacing the steam valve assembly?
完成的
Referencing the ifixit tear down: Starbucks Barista Teardown
Looking at the second picture of step 8 of the teardown, it appears the steam wand is threaded into the boiler. If you were "never" going to use the wand, you could unscrew the steam wand/valve assembly and screw in a cap.
完成的
Thanks, Tim. I looked at the Teardown and I still have a question: Do I need to remove the boiler in order to remove the Steam Valve Knob Assembly? I undid the allen screw -and- loosened the brass nut which seems to lock the Steam Valve Knob Assembly to the boiler and the SVKA will not slide off. Should I try a rubber mallet? :D
完成的
If it was me, I would try other things before resorting to "percussive persuasion".
In the ifixit tear down, they removed the screws to the boiler assembly and then the screw to the knob, which suggests the entire boiler assembly needs to come out to slide the valve away from the knob.
完成的
I simply put a cap on the end to get around the whole valve assembly. From watching one of the videos, it seems like you have to remove the entire boiler assembly to get the steam valve out. Thanks.
Wife Question: What is the next step up in machines when we want to get a new machine? This one has lasted 10 years, but clearly it's not gonna last forever.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
JC Harris 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 909
