跳转到主内容
The Nikon D5500 is a mid-tier consumer DSLR announced by Nikon on January 5, 2015
How replace a broken screen glass of my Nikon D5500?
Hello everyone
My Nikon D5500 fell to the floor and broke the screen glass, but the LCD display is OK. How can replace it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Replacement screens cost $10-20 and come with the glass.
完成的
is this could solve by replacing the glass only, or should replace include the lcd ?
i've the same issue searching for glass lcd only but can't found in any marketplace
完成的
添加一条评论
1个答案
最有帮助的答案
i know this is a repair guide for an earlier camera in the same family but the camera bodies a very similar and come a part in pretty much the same way...
Nikon D5200 Screen Replacement
这个答案有帮助吗?
得分 3
1条评论:
The D5500 and D5600 follow a similar procedure. Remove the 4 black screws from the corners of the screen to access the back of the screen. Unsolder the 4 black, blue, yellow and red wires and remove 3 ribbon connectors. Remove the 2 silver screws in the hinge to release the screen assembly. The LCD is held in by doubled sided tape on the outer perimeter of the glass. To remove the screen hold the thin black bezel and push the back of the screen firmly. The yellow circuit board the ribbon connectors plug in to on the back of the screen does not come with most replacement screens. Gently pry the plate off exposing the mirrored backing of the LCD and swap it on to the new screen.
完成的
添加一条评论
添加你的答案
Diego 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 45
总计 2,604
