跳转到主内容
加入维修社区 - 创建账户
The Motorola Droid Ultra XT1080 is an Android (4.2.2 Jelly Bean) smartphone with 1.7Ghz Dual-Core median processor. It was released 23 July 2013. This device is also very similar to the Droid MAXX.
Are the display and glass fused as one unit?
Hi, my friend is giving me a droid ultra but it is cracked and i might want to replace it in the future. i have one question though are the display and glass fused as one unit or are the seperate? it would be nice to only replace the glass cause the touch buttons at the bottom only the back button works. the home and multitask buttons dont work at all anymore.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@dudefoxlive, Keitaro, Yes, the glass can be separated from the LCD, see video link's below on how it is done and link to replacement glass which you can also do a search on for better pricing. Good luck.
https://www.youtube.com/watch?v=X5LBMH_y...
https://www.youtube.com/watch?v=yn8xvhFO...
https://www.amazon.com/Replacement-Part-...
这个答案有帮助吗?
得分 3
5条评论:
sadly at the moment i can not view the video due to filtering on my school wifi. i plan to replace the screen at some point in time but not right now. for the time i am going to use an app for the home and mutlitask button replacement.
完成的
well after looking at the videos turns out the glass is glued to the lcd which is not something that i am very comfortable trying to remove. it would be easier for me to just purchase the whole assembly as one unit LCD and digitize already glued together as it would be much easier for me. plus the screen has LCD burn cause the previous owner never locked the phone when he was not using it so it was always at the home screen and it got burned into the LCD.
完成的
@dudefoxlive, Keitaro, Yes, much simpler repair to replace the assy., thanks for posting back. Good luck with your device.
完成的
@lpfaff1 i will say this if you do it be careful when putting the board back into the housing. i broke the volume buttons and they need to be replaced. if only i can fine the part somehow.
完成的
@dudefoxlive,Keitaro, Best to just try a search using your make and model# for required replacement part. I will post a link below, it may be the part you need.
https://www.mobilesentrix.com/motorola-d...
完成的
添加一条评论
添加你的答案
Dudefoxlive 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 17
总计 300
