跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Direction of power button during asembly
I believe i am doing something wrong as my power button is depressed and won't move after I assembled it. Which direction should the lever on the power button move? One side moves completely flat versus the other side remains slanted
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
6个答案
已选择的解决方案
hi birdie,
think i answered this a few days ago.. the silver ring hangs downwards and sits in a little groove on rear case. when you put the screws in make sure not to over tighten them- sounds like you've got one of yours tighter than the other. take button out and try again, if this doesn't work you might have to flip the button round (some have a right side and a wrong side) it's a tricky/fiddly fix and i sometimes do it several times before it finally works. good luck
这个答案有帮助吗?
得分 2
添加一条评论
The problem seems to be that is not reaching down and has no support and instead it sunkens down
这个答案有帮助吗?
得分 0
1条评论:
try a bit of tape to hold button in while you put screws in
完成的
添加一条评论
It sunkens after i\I put the screws in and press the power button down. Any idas?
这个答案有帮助吗?
得分 0
1条评论:
Did you replace the rear cover? Your first question was after a drop
Can you post a photo of back case without button in? + with?
完成的
添加一条评论
Yes I replaced the back cover, it looks identical to the original. I dont have a camera with me now. What are your thoughts?
这个答案有帮助吗?
得分 0
1条评论:
Just wondering if the place where power button fits hasn't been manufactured well enough to house power button. If the groove isn't holding the silver ring maybe this is why it is lopsided and not springing
完成的
添加一条评论
I put a piece of tape, the screws and when pushed it still sunkens down. I give up
这个答案有帮助吗?
得分 0
1条评论:
have you tried a bit of tape wrapped around the silver ring to push it up a bit in the housing?
完成的
添加一条评论
I could try that. I am trying to suspect I was sold the wrong button cause this thing just sits there and it shouldn't be this hard.
这个答案有帮助吗?
得分 0
1条评论:
quality of housings and fittings really varies. get back in contact with the supplier. if you bought off ebay then really read their feedback before buying. I've never had as much trouble as your having!!!!!
完成的
添加一条评论
添加你的答案
Birdie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 691
