跳转到主内容
An in-car GPS manufactured in 2012 by Garmin.
10 个问题 查看全部
Charging port no longer charges
I have replaced the battery on my 3590.
The new battery (tried two different ones) was fully charged before connecting it.
However, whether I plug it into:
1) The wall charger
2) Laptop USB
3) Cradle charger
The battery will not charge.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Colin Marson , I take it worked on the new battery till it died and now refuses to charge. Did you check the port and blow any dust/debri out of port. Look in port and straighten any bent pins with tooth pick very carefully. Still no go, remove battery door and with a DVOM with charger plugged into device check plug at battery to see if charger is sending voltage to battery, if not probable loose/bad charge port,change the charge port. the link below is a tear down guide that can get you access to the charge port which is soldered to the mother board and is not a job for the newby because of the fine components and heat involved. 2nd link shows a charge port being resoldered.Good luck.
Garmin nüvi 3590 LMT Circuit Board Replacement
https://www.youtube.com/watch?v=5z5KLwKn...
这个答案有帮助吗?
得分 0
添加一条评论
The difficulty is that neither the USB port nor the cradle connection seem to be providing a charge ( the battery icon does not show that it is being charged)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Colin Marson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 6
总计 2,047
