It has Ghosting problem
I bought a used Samsung Galaxy Tab S2.
It has ghosting. Can it be repaired?
If yes, how or where can I send it for repair?
@sam1023sung , Sam Sung, Mix up 4 ounces 70 percent isopropryl alcohol (rubbing alcohol), 4 ounces distilled water in a misting bottle and spray on(dampen) a soft cloth/micro fiber and clean your screen really well. Turn on device and try.
Still not working properly try a factory reset.
-If the display is off, press the power button to turn it back on.
-Afterwards go to settings and then to backup and reset.
-Tap factory data reset and reset device.
-Choose erase everything if you are sure you want to clear all your data.
-Select OK to confirm the whole operation.
The hard reset is done, try device. Other rest procedures at link blow.
Still have the ghosting, may require a new digitizer, do not want to do the repair, have a good local computer/cell phone repair shop have a look, diagnose and estimate repair. Good luck.
这个答案有帮助吗?
过去 24 小时: 9
过去 7 天: 10
过去 30 天: 13
总计 1,535
