跳转到主内容
The Nokia 5800 XpressMusic is a Symbian-powered smartphone and portable entertainment device by Nokia.
Why showing offline on the screen
Show offline.
Setting could not take care of offline showing on the the screen. I cannot make call because it is asking for SIM. And sim is inside the phone
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi,
Have you tried a different known working network compatible SIM card in your phone to see if it works OK?
Have you tried your SIM card in another known working network compatible phone to see if it works OK there?
What have you tried?
完成的
添加一条评论
1个答案
已选择的解决方案
Switch it off, remove the sim and check that it's clean, now push it back in as far as it will go (use the stylus to help you).
Now switch back on.
If it asks you if you want to continue offline say no. If it doesn't ask and is still offline try selecting the "general" profile and see if it gives you any error messages.
If it still fails to work try another sim card to find out if it's the phone or your sim that is having a problem with that phone.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Femi Awosanya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 1,121
