跳转到主内容
Released in March 2013, identified by model number S500CA-SI50305T
12 个问题 查看全部
How much ram will an asus s500ca support?
I have two asus s500ca's one with an i5 processer and one with an i3 I was hoping to install some extra ram in both of them and I was wondering what they would both max out at. I've done a few google searches and answers range from 6 to 16 gigs. I was also wondering if they can actually only handle 6 gigs what will happen if I were to put 8 in would it just not use the excess it cant support?
Any help is appreciated thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
8gb is the maximum amount of RAM your laptop can handle according to the manual. Not sure what happens if you go over this. Either you will only see 8gb or you will actually see however much you put in. Either way the laptop will work normally (at least it should).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Brad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,183
