Different models of ps4 controllers
I bought a shell and it doesn't fit either of my current controllers. The screw on the top part is on the left. Which model do I need.
@nlthor , Nick, There should be a label on the controller, you will have to check the model # on the controller to get the correct part as they do make revisions(slight changes). Below is a link you can click through to see the various controllers and the 2nd link is a vid. showing some revision on controller. Link #3 talks of aftermarket/copy cat controllers that are not put out by Sony and could be significantly different inside. Good luck.
https://www.google.ca/search?q=ps4+contr...
这个答案有帮助吗?
Is there a way to tell on the box? I just bought my controller, and only the D pad and thumbstick can swap out for the mod buttons/triggers
I got a brand new ps4 cuh-2115b model for last Christmas (12.25.17). Somebody took control or I misplaced it somewhere. Out of curiosity, is the controller going to have the cuh-2115b label that the console has or is going to be cuh-zct2u that ps4 controllers have?
The blue controller is the old one and the red controller is the new one
Look closely between the r1 and r2 button
when you disassemble both controllers the motherboards and motherboard holders are different. They also align differently as you can see in the picture below.
Hope this helps!! Ps. Internal parts for the new(red) controllers are very difficult to find. If anyone knows where I can find internal parts (specifically motherboard holder) drop the link.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 26
总计 45,255
2条评论
由 Igy E 完成的
How do i check my ps4 conteollers module number?
由 Neydaaxo Moncayo 完成的
